350 chev
muffycaz, Jun 9, 1:27pm
Reco,350 chev,boat motor,Before start up have spun oilpump for 3 min,plenty of pressure at electric oil sender,and external filter.But no sign of oil at rockers,Is this a concern.
les6, Jun 9, 1:50pm
give it another 3 mins!
muffycaz, Jun 9, 2:01pm
The drill im using is a cordless 2 speed .I used this on fast speed,may be not quick enough.ill try longer.
kingfisher21, Jun 9, 2:19pm
You probably won't get it at the rockers as it has to go through the hydraulic lifters first, just make sure you have a bit of oil over the rockers etc, get oil pressure the way you have already done it, put the dissy back in and fire it up.
cuda.340, Jun 10, 8:29am
while you are priming with the drill, get a mate to turn the engine over, you should start to see oil at the rockers after that.
moparpete, Jun 10, 8:53am
Yep do what Cuda says. Had the same problem with my 360. Especially if motor has been sitting for a while.
ceebee2, Jun 10, 12:09pm
They work on quite low oil pressure anyway so will take ages that way. As Kingfisher says it has to prime the lifters with "splash" first.
