Had a VTNZ PPI done on an 03 Fairmont i looked at today. Had a few issues as can be expected with a 9yr old vehicle. Would have failed a warrant on right front ball joint left front ball joint also needs attention right rear suspension bush/es also need attention brake fluid >3% moisture needs replacing both headlights dipped out of alignment
Can anybody give me a rough estimate to get these issues sorted! Cheers.
thunderbolt,
Jun 7, 2:27pm
My ballpark $700-$800 dollars. Why dont you ring your local Ford dealer for a quote. They may want to know if the ball joints are upper or lower, and which suspension bushes are worn. It will be higher than your local workshop but gives you a quote to bargain with
happylad3,
Jun 7, 3:56pm
if they are the lower front ball joints, i just did them on a 2001 fairmont and they were $36 trade price at bnt. and took me about an hour and half each side to replace. need a press to remove and refit them to the the arms.
