VE dual climate control
monaro17, Jul 12, 6:16pm
My VE has a problem with it's dual climate control system. The air only ever comes out of the front windscreen vents regardless of what function I select- face, bi level, feet or what ever- the air always just comes out of the windscreen vents. Why does this happen! Has anyone encountered the same problem!
mantagsi, Jul 12, 6:34pm
I am going to hazard a guess; if it is anything like a couple of jappas I've had, the little direction flapper in the heater box is stuck, or the servos that drive the flapper are defunct. at first I wondered if it might be like some earlier commodores with the vacuum operated heater box but I doubt that, being such a new car. I can see this becoming a very time consuming repair as getting to the heater box is not easy
bigfatmat1, Jul 12, 6:35pm
there is a little wee stepper motor that controls the direction. Could be a broken or jammed linkage faulty motor or a controller fault.
prohunter1, Jul 12, 7:12pm
just had mine in my falcon replaced did the same thing. 2 grand! lucky was still under 3 month dealer insurance
clark20, Jul 12, 7:52pm
I have the same, it will not blow air at your face or feet until it is warm. Change the settings while the car is stopped and see if you can hear the flaps changing
monaro17, Jul 13, 7:58am
I have noticed this. When the car is idling hot air will come out of the other vents if selected but it soon turns itself back to windshield vents only. So annoying, especially on hot days
