Indicator Help!
dazza135, Jul 10, 9:30am
Okay, so my left front repeater has stopped working. Replaced the bulb, still nothing, I even checked the bulb in the right hand side and it was fine. There wouldn't be separate fuses for both sides would there! Car is a 1993 Toyota Corolla, 1.3L, Manual, Hatchback.
bellky, Jul 10, 9:44am
My guess is a bad earth there somewhere, usually around the bulb(s) and/or where the unit touches the body of the car etc. You need to take all the lenses off and fiddle around with the bulbs and earths.
budgel, Jul 10, 10:04am
What he said!
lew124, Jul 10, 1:20pm
some of those corolla flashers rely on a copper strip to contact the bulb. If so just play with it, clean it or some such thing
marte, Jul 10, 1:42pm
Does it work on the 'hazard' setting!
dazza135, Jul 11, 10:07pm
Cheers Mate. It wasn't quite making the correct contact. Easy Fix = Easy WOF
