Towball size .
sully12, Jul 11, 3:28pm
Hi there, this may be a silly question but I am needing a towball for the car and have just realised there are two sizes.Does anyone know if most garage hire trailers would use the same size or could they all be different!
Towball I am looking at is 1 7/8".Thanks.
lookoutas, Jul 11, 3:30pm
You need to ask the garage.
1 7/8" (48mm) is the standard size.
sully12, Jul 11, 3:32pm
Thanks for that.I didn't even know there were two sizes.Will check with the garage on the way past this evening.
daryl14, Jul 11, 3:34pm
1 7/8 is nz standard on most trailers. 50mm or 2 inch is more from industrial or USA stuff. You can even get tow balls that convert between the sizes. Just go to supercheep etc and get 1 7/8 for most applications.
sully12, Jul 11, 3:41pm
Thanks daryl14.Will do that.
msigg, Jul 11, 3:43pm
50mm is the standard now.
milo_20, Jul 11, 4:24pm
Most garage Hire Place's have A DUOFIT 1 7/8" & 50mm Cuplings On There Trailers.
rob_man, Jul 11, 4:30pm
I carry both sizes and change the towball if I need to, it's a pain in the arse.
morrisman1, Jul 11, 4:45pm
While 95% of equipment uses 1.7/8! I wouldn't call 50mm standard myself
net_oz, Jul 11, 5:18pm
I changed my tow hitches to 50mm to stop everyone else borrowing the trailers. Worked so far.
neo_psy, Jul 11, 5:26pm
Slightly OT, but still funny.
Years ago, my sister and her husband bought a new (to them) car with a towbar. One day, BIL went to the servo to hire a trailer for something and the hitch wouldn't fit.
Someone told him their were two different size towballs, and he figured he must have the "other" one (from the trailer) so he'd take the towball off his car (for reference) and go to Repco and buy the other one.
Not being mechanically minded, and not having many tools, he skinned his knuckles trying to take the ball off with vice grips.
Eventually, he figured out that there was a cover on the towball he was trying to remove.
ralphdog1, Jul 11, 5:29pm
You can get an easy change option where it is a simple no tools job to change from one size to the other, but they are not cheap.
Set an 1.7/8 but be careful when you hire a trailer with a combination coupling that you use it in 1.7/8 mode and not 50mm mode.
