I mean it moves and if it breaks down you can always do a Flintstones and use your feet
gemmigem,
Jul 9, 12:51pm
It's only minor rust ! , a bit of bog and a respray it'll be good as new !
friendly_prawn,
Jul 9, 1:20pm
done that more than once in thepast.Fuel can in the cab with hose out the window to the carb/fuel pump. Young and stupid. not sure I would too readily consider it now days though.
rob_man,
Jul 9, 3:39pm
Been there, done that. A 55 chev with a rusted tank so we used a container sitting on the passenger's floor with clear plastic hose for a fuel line out the window. Nothing new under the sun.
Jul 9, 3:48pm
Sheesh car drivers are such wimps. Bikers ALWAYSride with their privates pressed against the back of a 15-30l fuel container that sits directly over a set of spark plugs.And its legal
sr2,
Jul 9, 4:20pm
Reminds me of the test drives we used to do half way through an engine transplant. A quick blast around the block sitting on a beer crate with no transmission tunnel, an oversized motor poking through a big hole in the firewall and a mate holding a 1 1/2 litre coke bottle with a tube hanging out of it for a fuel supply!
v8_mopar,
Jul 9, 4:26pm
Ive never had a gas can inside the car before but i have had to put a wooden floor in a triumph herald
skin1235,
Jul 9, 4:30pm
this guy put some thought into it too, note the electronic fuel cutoff he has wedged to the A pillar personally can't see any issue with the fuel system, he's even used a bona fidefuel tote designed to work in confined spaces, way better than the glass flagons we used in the day
tonyrockyhorror,
Jul 9, 4:56pm
And yet no crash. it's almost as if a WoF system like the one we have is a waste of everyone's time and money when clearly the driver is by far the greatest risk.
rob_man,
Jul 9, 5:02pm
Haha. Been there too, all sorts of funny noises because the clutch linkage isn't quite perfected yet. Open headers and carb backfiring because nothing's been tuned properly, overheating likely due to air locks in the system and is the radiator big enough for that motor anyway!
