How much of Coolant/Antifreeze Would a Mitsubish.
joaopnz, Jul 8, 1:11pm
Hy Guys.
Does any one how how much Coolant/Antifreeze would a Mitsubish Colt 2004 1.3 take after flush!
Thank you,
John
tonyrockyhorror, Jul 8, 2:58pm
The system capacity is 4.6L for the 4A90 according to Autodata. So you best put 2L of concentrate in then top it off with water which will give you 45% concentration.
joaopnz, Jul 8, 6:18pm
Tks man. What about the Premixed stuff, just as good as concentrated!
morrisman1, Jul 8, 8:15pm
well premix potentially better because it reduces the chances of your water having crap in it like minerals and dissolved solids.
tonyrockyhorror, Jul 8, 10:29pm
Yeah. But the problem with premix is getting the right concentration if you've left water from the 'flush' in the system.
n1smo_gtir, Jul 8, 11:05pm
you are doing a full flush involving taking the thermostat out and flushing the engine and heater cores too right, and not just pull the bottom hose out and put it back in after radiator empty. sounds silly but you be amazed at what people would consider a coolant flush.
