Juat spent the last 3 days prepping the bonnet, 2k primer, then base coat all went on fine. Im having trouble with the clear coat though. Seems to be "flaking" as I apply it, hard to explain but I end up with little white specks and after the flash time I can blow of what looks like dust but it's not. Any ideas!
gunhand,
Jun 30, 3:41pm
Hard to imagine whats going here, I take it you have put the hardner and reducer in the clear!Are you applying it wet! What PSI your gun at. What brand of product you using.
rob_man,
Jun 30, 3:41pm
Dirty gun for white flecks! Water in the air line! Dust effect could be overspray settling on the surface after it's tacked off a bit. You may have the pressure a little low too, it needs to be higher for the clear than the basecoat. edit: too many variables .
gunhand,
Jun 30, 3:43pm
UM, what are we looking at lol. Looks like a biscut.
kinger3,
Jun 30, 3:43pm
shit, first time ever doing this, didnt realise you were supposed to put reducer in it. thats why I had a shitload left over. damn it
gunhand,
Jun 30, 3:46pm
Most clears can be applied with out it and you use very little anyway. Me thinks your not using enough pressure especially if you have reduced it.
What brands you using!
kinger3,
Jun 30, 3:46pm
whats the ratio!
kinger3,
Jun 30, 3:46pm
I thought I may have been using to much so turned it down, what should it be at!
gunhand,
Jun 30, 3:47pm
Mostly 2:1 plus 10% reducer, sometimes 15%, depends how you like it but 10% is what I go for.
rob_man,
Jun 30, 3:47pm
Are you sure it's 2k! Sounds like dulon cobwebbing to me.
gunhand,
Jun 30, 3:48pm
Rings a bell here to, an old bell thank god.
gunhand,
Jun 30, 3:49pm
I use 30psi at the gun regulator.
kinger3,
Jun 30, 3:49pm
yup its dupont selectclear
gunhand,
Jun 30, 3:50pm
And unhardend or reduced 2K clear may well do the same thing (cobwebbing) but if you got it on it wouldnt dry let alone flash off.
gunhand,
Jun 30, 3:51pm
Havent used it sorry but instructions are/should be on the can.
kinger3,
Jun 30, 4:02pm
PSI was the prob, upped it and bang good as gold
gunhand,
Jun 30, 4:03pm
Cool, hope it goes well.
grangies,
Jun 30, 4:14pm
Yikes. Your pressure must have very very low for that to happen.
What sort of gun are you using!
Do you know your fluid nozzle size!. Because at a low pressure any thing from 1.2mm up should atomise 2k clear at low pressures. UNless the nozzle is at the other extreme. As in above 2.0mm
gammelvind,
Jul 1, 7:38am
Solvent popping maybe, hard to tell in picture.
