Coil Spacers?
hairchopper1, Jun 26, 7:24pm
Can I just add them in and get the lift I want or is there more to it!
morrisman1, Jun 26, 7:25pm
yea, or you could get the right springs for your car.
hairchopper1, Jun 26, 7:28pm
just wanting a bit of clearance around guard for bigger tyres on farm vehicle. Do you think that would be a cheap option and easy enough to do myself! (no mechanic but not stupid)
morrisman1, Jun 26, 7:33pm
you may lose some articulation if your shocks end up not far from full extension. Hell its a farm vehicle, give it a shot and if it works then great.
and please be careful with compressed springs when dismantling/assembling. Spring compressors are cheap!
pico42, Jun 26, 9:34pm
What vehicle is it!
What lift do you want and why do you want it!
hairchopper1, Jun 27, 6:02am
Jimny flatdeck ute to fit bigger tractor grips on so probably about 50mm lift I think. I've seen the body lift kits on here but I think the coil spacers might be easier and cheaper.
morrisman1, Jun 27, 7:01am
If its a long term thing the. What about a spring lift kit with new shocks to suit! Can you body lift those! I thought they would be a monocoque design
