I have a diff for sale and someone has asked if it is LSD The diff is sitting in my shed and hubbys away and i dont know much about these things Thanks Chrissy
illusion_,
Aug 8, 7:01am
what colour is it!
tinbox959,
Aug 8, 8:04am
illusionCheeky bugger Ibet you offer candy to little boys also
andrewph,
Aug 8, 8:18am
If its a complete diff with axles you can turn one axle with a steel bar between the wheel nut and watch the other side if they both turn in the same direction its LSD or if they turn in opposite directions its a standard spider geared diff.
tinbox959,
Aug 8, 8:52am
Its out of a xa coon 302v8 1973 Cheers for the info Chrissy
ceebee2,
Aug 8, 9:15am
If its only a diff head with no axles etc, then as per andrewph but observe the "holes" on the sides where the axles fit into. Also should have a steel tag under the oil level nut for the LSD diff.
srrolla76,
Sep 22, 8:16pm
if they both turn the same way its lsd or lock diff. its a single spinner if they turn opp ways
