Hey would any1 know whats wrong with my kar! the batery is on full charge and i just changed the alternator but when you try start it it just seems like the baterys flat and wont even turn over, but you can push start it and it runs fine!
just changed alternator and batery terminals and il check earths but it was running fine a few weeks ago so dno how they would come loose!
satans_child_nz,
Aug 4, 4:59pm
starter!
Aug 4, 4:59pm
As above, check battery and starter motor terminals, earths, etc.
murphy45,
Aug 4, 5:02pm
ive had an auto sparky check startermotor he rekons it fine! and i just changed the alternator
satans_child_nz,
Aug 4, 5:11pm
try another battery, could be too old or worn out
murphy45,
Aug 4, 5:13pm
already tried 3 lol
Aug 4, 5:22pm
The starter may be fine, but are the wires that go to it secure!
andrea_w,
Aug 4, 5:35pm
Sorry mate, my brain was thinking one thing and the fingers typed another. I meant Starter motor but someone has already suggested that now
chebry,
Aug 4, 6:05pm
Is the engine block earthed properly Jap cars tend to have the lightest cables they can get away with
fern413,
Aug 4, 6:33pm
Have u got a testlight or voltmeter!If you do take start wire off and measure while in start position. If you have no power there you can rule out starter, earth, main posotive leadfor now and need check start relay if it has one and see what youre getting there. Auto or manual!
thunderbolt,
Aug 4, 6:34pm
Does it crank over ok with jumper leads connected!
next-to-normal,
Aug 4, 6:51pm
get some new battery leads, as before use jumper leads to check your earth, and try another battery just in case,
murphy45,
Aug 5, 6:25am
na doesnt start with jumper leads and its been comverted 2 manual
fern413,
Aug 5, 8:47am
Did u put a voltmeter on the start wire!
gmphil,
Aug 5, 8:57am
Seized!
thunderbolt,
Aug 5, 9:01am
Have you been able to start the car normally since the manual conversion! Maybe an issue with starter engagement! Wrong flywheel or similar!
hopie,
Aug 7, 8:47am
manual conversion puts a whole different light on the situation. Did you bridge the inhibitor switch to think the car was in netural! was also thinking starter till this little bit of info came up.
kcf,
Aug 7, 12:51pm
I also immediately thought of the inhibitor switch when he said manual conversion.
Have you checked that volts are actually making their way to the starter motor!
jason18,
Aug 7, 12:56pm
Bit with the inhibitor switch it wouldnt even crank over tho would it! Or doesnt it crank over! The new alternator been wired properly! Is it even charging
jason18,
Aug 7, 12:57pm
Oh it doesnt turn over. my bad. Sounds like that switch needs bridging so it thinks its in neutral
hopie,
Aug 7, 1:53pm
sounds that way, do you no which wires to bridge!
