I want to rattle your brain.
fordoverholden, Aug 5, 4:07pm
91 Nissan pulsar. When i turn left and right i can hear a creaking noise. Turn the car off and i get the same thing. Its not a clicking CV noise. Its more of a inwards sounding noise. I think its only coming from the left. I checked the power steering fluid and it fine. Any ideas! Thanks!
1coppertone, Aug 5, 4:18pm
more info needed!
rob_man, Aug 5, 4:20pm
Power steering belt could be slipping.
grangies, Aug 5, 4:20pm
Is the steering shaft rubbing on something!
1coppertone, Aug 5, 4:22pm
left hand wheel bearing loose and center nut needs tightening!or could be ball joints,or steering rod ends! best to jack front of car up and feel for play and then go from there
1coppertone, Aug 5, 4:24pm
cant be steering if noise is still present when motor is off.
fordoverholden, Aug 5, 4:24pm
what do you wana know man!
fordoverholden, Aug 5, 4:25pm
Na i would feel it tho the wheel. Thanks
fordoverholden, Aug 5, 4:26pm
Na because when you drive every think is normal
Na not a PS problem. Thanks tho:)
grangies, Aug 5, 4:28pm
Slow down, and get your spelling correct. Otherwise the nasty's will come in and ruin your thread. It happens all the time in here.
fordoverholden, Aug 5, 4:31pm
Ah i work with the IHC every day. Ant no one gonna annoy me on here. lol. the nasty's can watch the Olympics
1coppertone, Aug 5, 4:36pm
creaking noise as in the shocks!similar to the squeak of that of the old ford falcon! lol
morrisman1, Aug 5, 4:57pm
is it the top shock mount rubber creaking when the strut pivots!
beblowin, Aug 5, 5:01pm
inner bush worn on the bottom arm
1coppertone, Aug 5, 5:08pm
i reckin you just nailed the problem beblowin!
ambo11, Aug 5, 5:18pm
Had one of these years ago that did a similar squaek to this, replaced the large bushes which hold the steering rack to body and problem gone.part of a WOF check too I think!
pc_evo, Aug 5, 6:12pm
Either that, or its doing what the navara's do, and creaking at the top of the springs, both old and new navara's (at leats the venturere's) still do it. Dunno bout the STX, but . there not really navara's anyway
johnf_456, Aug 5, 6:14pm
A very good point.
biddy6, Aug 5, 7:16pm
Steering rack working/flexing on its mountings
hopie, Aug 6, 8:16am
does it have top arms like the primera! these things are notorious for failling. and sweak like a mofo
