Anybody tried ThermalWeld to fix blown headgasket?
kevin_the_kiwi, Aug 4, 12:48pm
Somebody just text me about fixing my car that has a blown head gasket for $100 DIY. Seems to good to be true.
http://www.thermalweldnz.co.nz/index.htm
chebry, Aug 4, 1:16pm
Like most miracle cures it is too good to be true
quickstitch, Aug 4, 1:27pm
we used another similar product, chemiweld, in a big block chev race car with a cracked head. running 12 1/2 to 1 compression and it worked to my surprise. got us thru the meeting.
sas777, Aug 4, 1:53pm
Yep it will probably work well for a while. Great if you need a quick fix -have used that liquid copper one a couple of times on drill rig support gear to get through a job.
Then you bring it to the workshop, pull it to bits and fix it properly.
So if you are after a miracle, no, just do it right in the first place.
carlz05, Aug 4, 3:42pm
Yep, tried chemiweld which is similar as mentioned above.Works for anout 3 -6 months max, then blows out again.A proper fix ended being pulling it to bits and doing a proper repair.
john_rizic, Mar 12, 10:03am
I have used www.thermalweldnz.co.nz many times for all makes and models of vehicles including big rigs, tractors in the field...you name it and have been more than satisfied. Hey, it does come with a guarantee.
