Ride on mower help :)
small-motor-guy, Jul 30, 5:35pm
If i drain the?
desmodave, Jul 30, 5:44pm
Why would you need to tip it on its side . Cantyou just drop the deck off to work on it.Bit of oil smoke from being on an angle wouldnt bother me
small-motor-guy, Jul 30, 5:46pm
Hi no have just rebuilt the back diff/gear box and it is going to be hard to hold it up and put every think in place. had to reseal it and put new oil in.
cheers
small-motor-guy, Jul 30, 5:48pm
Its also easy to drain the oil, has a little tap thing on the side witch you trun to drain it, might put new stuff in while im at it, just dont wont to kill my motor from having it on its side!
singing1, Jul 30, 7:38pm
Is it an LX series!
solarboy, Jul 30, 8:17pm
You've still got the battery disconnected I guess so that'll be easy to take out then .Unless it's a SLA then you can leave it in of course.
small-motor-guy, Aug 3, 3:36pm
Thanks guys, have found out that yea I can tip it over if the oils drained out :)
