1kz flywheel
tonym8, Aug 1, 5:36am
will a 2lt flywheel fit a 1kz motor ! does it need drilled are they balanced the same ! any info would be great thanks
lk104, Aug 1, 6:26am
No, they are different.
Why do you want try and put in a 2LT Flywheel!
mugenb20b, Aug 1, 10:11am
What's wrong with buying a new one! They are readily available.
tonym8, Aug 1, 10:53am
i'm going to put a 1kz in replace of a 2.4 t motor didnt come with flywheel i've already got the 2.4 1 and someone said they fitted and it would be good to know before i start and if yoy dont ask you will never learn anything thanks
trader_84, Aug 1, 2:24pm
What box was behind the 2LT . a G series or an R! I've only ever seen R150/151F's behind the kz series donks and G series behind the 3L's . but am unsure of what came out behind the 2L's.
tonym8, Aug 2, 4:00pm
R151F Box
intrade, Aug 3, 3:24am
all different. not even the L flywheels fit each other till 1988 there is less bolt holes on flywheel then there is on 1989 model L engines. I presume you got a buste DMF dualmass flywheel. i got quoted 750$ years ago to build a solidmass one with the old ringear for the L engine.
saffa2, Aug 3, 3:59am
Don't know about l and/or t motors but my '88 2.4t crapped the flywheel and we replaced it with one out of a late 90's hilux, there are two different bolt patterns just gotta get the right one.
trader_84, Aug 3, 6:36am
Get ahold of nomis9 on here. He knows sh1tloads about luxy's and might even have what you are after if what you have does not work.
