Mags offset?
roys351, Jul 28, 5:11pm
anyone know the offset for 8 inch tridents 8jj14
snoopy221, Jul 28, 6:56pm
That's a bit like the *tightness** of *sinkin the pink*
Ya KNOW ya either measure it-or look at the writin on da wall.
sw20, Jul 28, 7:04pm
Do you understand what offset is! I'm assuming you don't because no one can answer your question without having your wheels physically in front of them.
Offset is the distance in mm that the plane of the hub mounting surface sits at compared to the centreline of the rim.
You can measure them yourself easily. First, measure the overall width of the wheel (will be larger than 8 inches btw) Next, divide that width of the wheel by two; this will give you the centreline of the wheel. Overall width/2 = centreline.
After determining the centreline, measure from the hub-mounting surface of the hub to the edge of the inboard flange (if the wheel were laying flat on the ground ??
