Replacing rocker cover gasket in a 95 mirage.
hoarder85, Aug 29, 6:20pm
any ideas of the approximate cost! Engine has been leaking oil and two pieces of the gasket are protruding from under the rocker cover where the oil is leaking so I am fairly certain that this is the problem. TIA :)
mugenb20b, Aug 29, 8:05pm
Gasket $25 or so, labour 15 minutes. You can do it yourself, it's only half a dozen bolts, peel the old gasket off, clean all the gasket mating surfaces, fit new gasket, bolt the rocker cover back on. Job done.
hoarder85, Aug 29, 8:07pm
Awesome, thanks!
spottie, Oct 7, 2:53am
Don't overtighten the gasket they don't like it.
