Square cut o-rings
lugee, Aug 30, 8:14pm
Really having a hard time finding some small square cut (as in, square rather than a round profile) o rings, around 10-11mm ID. Anyone know of a place to get these! (Note already tried all automotive stores and a few others)
easygoer, Aug 30, 8:17pm
Have you been to Seal Imports 29 Nga Mahi Rd Sockburn, Christchurch
lugee, Aug 30, 8:30pm
No, will see what they can do.
purple666, Aug 30, 10:27pm
Depending on what you are trying to seal try a Plumbing Supply place.
mokaubach, Aug 31, 1:45am
These guys can pretty much make any seal you need :
http://www.sealjet.co.nz/index.php!section=1
tmenz, Aug 31, 1:47pm
Are you sure you need a square one! Some applications like tap bodies use standard round 'O' rings in square slots so the rings conform to this and when they get old they stay square!
blue35, Aug 31, 5:17pm
They are called quad rings, got some imperial ones off Seal Imports last week.
40wav, Aug 31, 5:20pm
Can you punch out your own from some insertion rubber with suitable size punches!
chooken1, Aug 31, 5:42pm
What are you wanting the seals for!
lugee, Aug 31, 6:07pm
Its actually not for a sealing application. Its for a model locomotive, which takes small square cut o rings on the traction wheels so help it stick to the rails. Model stores couldn't help so I'm resorting to finding a similar o ring somewhere. The ring needs to be 10-11mm ID, 12-13 OD with a square profile. I'll try Seal Imports and see if they can help. Also,
Whats that supposed to mean!
chooken1, Oct 11, 4:53pm
There are square section seals for toyotacalipers, I dont know what the size is off hand, BNT sell them, I cant think of the part number either at the moment.
