Hi. I have a pair of hella universal headlamps fitted to my bike. I want to pull one apart to remove the cut off plate for the light beam in one so I can run one low beam (with cut off plate) and one high beam (without). My question for you fine people is, how do i crack the housing open to remove the plate! Light in question is a hella 161-782-00 Universal headlamp. Runs H7 bulbs. Cheers guys!
Similar but ts a 12v and its a bit older. Same basic setup though. Cheers
clark20,
Aug 25, 6:58pm
You may have to get in thru the bulb holder and bend the shield over
lookoutas,
Aug 26, 7:53am
That's the way
