around windows of cars, like the ole mini's & woodys you see in the States!
grangies,
Aug 24, 6:38pm
A cert!
ema1,
Aug 24, 8:21pm
No when it's that way from factory. You'd need to find out from a Low Volume Compliance person to get an answer to the question ( I think) you are trying to ask here! I assume you mean "After market or customizing" job .!
unbeatabull,
Aug 24, 8:30pm
Depends. Are you going to be replacing what it currently has with wood! Or were you more thinking of putting a wood veneer/layer over the top of what is currently there!
If you were replacing or changing anything it will need LVV. A layer/veneer over the top, I don't think there would be a problem, so long as it doesn't protrude or interfere with anything.
pnh4,
Aug 24, 9:38pm
Would like to use for bike too headlight casing, would one have to use a specific wood I wander.
bill-robinson,
Aug 25, 5:07am
as long as the wood is nonstructural I do not see a problem or need for certification. By that I mean it is pretty only, as on the mini.
