piston liner . the steel cylinder the piston goes up and down in, in a Toyota motor! The motor is the alum 4V 8 cyl Hemi but they should be similar to the alum 4 cly's of the same vintage, aye! How did they have their cyl's removed!
00quattro00,
Aug 17, 1:26pm
Are they not nikasil or alusil bores!
petermcg,
Aug 17, 4:54pm
There is a tool for this with a flat round plate and a long thread with a nut on it,, otherwise you need to warm the whole block in the oven and then spray some liquid ice in the bore, it should slip out like a solo mothers lover.
bill-robinson,
Aug 17, 5:08pm
That is two of them out, can you do the other sixjust the same way!( see quote)
trader_84,
Aug 17, 6:40pm
I had to google what you were on about . no - these are cast iron liners by the looks of them. I had another look at them also and . they look like they actually just float at the top and are fixed at the bottom.
00quattro00,
Aug 17, 6:44pm
Ah that explains there bigger size and weight
bubbles244,
Aug 18, 10:06am
hydraulic press. job for engine rebuilder most cases.
bert37,
Aug 18, 10:42am
one way is to run rings of weld aroundthem to shrink them
