Clubsport vs R8 Clubsport
bikemadandrew, Sep 2, 8:25am
Apart from air con and sound system, are there any other diffences between the two! I am looking at buying a VX Clubsport. Anything I should look out for! eg; common problems/faults
mantagsi, Sep 2, 8:29am
Im no expert but from what I've seen you shouldn't find any gremlins specific to the R8. There are some differences obviously, but a lot of the changes are cosmetic. AFAIK there is a difference in ECU state of tune, and I think the suspension is a bit nicer, but nothing wildly silly thats going to cause you grief vs a stock clubby. Good luck and have fun :)
a.woodrow, Sep 2, 8:35am
Check for oil leaks, particularly from the power steering rack. Check the brake pads and rotors all round, they are expensive to replace
a.woodrow, Sep 2, 8:39am
I meant to say the brake rotors are expensive to replace, not so much the pads.
bikemadandrew, Sep 2, 8:40am
yeah im sure i will have fun if i get 1 :)
clark20, Sep 2, 3:20pm
Yeah, watch for the discs if it has the upgrade package, and if lowered watch for inside wear on the rear tyres
