a rust hole (roughly 75mm2) an acceptable solution for a wof.Sealed and water proofed.No smart arse answers thanks.
gunhand,
Sep 3, 4:07pm
If its not structual yes you could get away with that I would think.
fordkiwi27,
Sep 3, 4:16pm
sweet as bro
flitt,
Sep 3, 4:28pm
I imagine they'd want to see the pop-riveted plate before you sealed it all up - as they would view a welded repair for a failed WOF.
splinter67,
Sep 3, 4:31pm
Has it failed a wof for the rust hole
icemans1,
Sep 3, 4:38pm
bog and paint makes a sinner a saint
gunhand,
Sep 3, 6:00pm
Im guessing,if it has already failed it will be structuall therefore you are not alowed to rivit panels on.More info needed.
ceebee2,
Sep 4, 1:29pm
I would have thought it had to be welded as in arc / gas welded.
splinter67,
Sep 4, 1:56pm
Dont you mean mig or tig
bellky,
Sep 4, 2:08pm
What about mug or tug.
the-lada-dude,
Sep 4, 3:34pm
check out the thread started by friendly pawn,he knows
timmo1,
Sep 5, 3:00pm
In NZ yes. In Australia it's 'Meeg' or 'teeg'
mrfxit,
Sep 6, 7:35am
Adding to the above, your answer is .
IF it's been noted as "structural" then it MUST be repaired & documented by a certified panel beater.
IF it's been noted as a "non structural" area, then you can do the repair at home but it must be a "clean repair" (Ie: no sharp edges, jagged bits , must be well fitted & secured etc)
most aircraft were built this way( alloy construction ) now there mostly glued. :::::::therefore go with technology annd glue the bugger on
merv4,
Sep 6, 10:39am
If it is a small amount of rust in the floor , I believe you are allowed to cut a hole with a hole saw and put a rubber bung in it;; stupid I know :: but I inderstand that is the rule.someone may correct me
joanie32,
Sep 6, 5:31pm
Yet you can build a car from scratch with out being a "certified panel beater" !
beno,
Sep 6, 7:16pm
the harbour bridge is riveted. so go 4 it
clark20,
Sep 6, 8:45pm
Told a guy to do that to a hunter floor, he thought it was a great idea, looks like it was meant to be there!
mrfxit,
Sep 7, 7:12am
Getting it certed for the road is a little different ****** Scratch built & repairs on a factory builtvehicle, 2 very different legal &structural situations
If the car sinks he may have bigger problems than a riveted panel!
