Mr2 head, price please.help?
iman007, Sep 6, 10:43am
had a look on tm but only found 1, is 250 about the going rate! im doing someone a favour to help them out, p and a if anyone knows please
tia
im in ch ch
phillip.weston, Sep 6, 11:28am
for 4A-GE 1600cc or 3S-GE 2000cc!
phillip.weston, Sep 6, 11:29am
or 3S-GTE turbo, or if really unlucky a 3A-U!
iman007, Sep 6, 4:17pm
get back to ya
iman007, Sep 6, 4:19pm
had to find phone
its a 1990 2 door 1998cc sports car.
any help!
cheers
sw20, Sep 6, 4:27pm
Ok so its a 3sge. So it needs a new headgasket! Or is the head warped so badly after overheating it you need a new one of those too!
Just get a replacement engine and swap over.
iman007, Sep 7, 8:01am
nah, the head is cracked and needs replacing, any advice!
bevharris1938, Sep 7, 8:11am
buy my car
iman007, Sep 8, 4:48pm
another freaking bump
someone must know what a heads worth!
grrrr
pyro_sniper2002, Sep 8, 5:45pm
You still haven't said if it's turbo. But as others have said you would be better off fitting a second hand engine.
iman007, Sep 9, 9:31am
thanks pyro, will pass on
ozz1, Sep 9, 11:00am
if you are going to buy a s/h head off trademe.!you had betterask if its been tested.otherwise its an expensive piece of alloy.
i can do a 3sgte turbo head. crack tested, hardness tested and vacuum tested.for $350 + $20 fght.
not a "bolt on" item. as you would still need to lap valves in , change valve stem seals and check tappet clearanceprior to fitting.
have3sgenon turbo head. but i would have to get that tested. prior to selling . same $.
iman007, Sep 12, 1:33pm
thanx heaps man, will pass onto my daughter as its her car, but im paying to fix it
cheers bud
pollymay, Sep 12, 2:12pm
3sge and 3sgte heads for the gen 2 engines iirc are the same, the manifold and everything bolts over from one to the other. Cams are higher lift on the N/A engine, consider it an upgrade. I used to have 2 heads off running motors and I couldn't get $60 for the pair on here after several tries so I threw them out.
