autoif it stalls it wont startcrank itfoot flat to floormakes no differencejust wont fire,warm orcold,but if I take fuel pump fuse out fires upstraight away, how can it"overfuel "being injected. !Gets a bit embarrsing when happens in town .
bellky,
Sep 4, 1:15pm
We have a '98 ES and I love it - hope this doesn't happen to us, although thanks for the tip as I now know what to do in that emergency :)
gmphil,
Sep 4, 2:22pm
Just out or out and back in to start!
nellie-mac,
Sep 4, 6:37pm
Hiya, dunno if 100% related but mine intially started fine then after a ten minutes driving started to miss fire then eventually die. spent hundreds chasing that fault only to discover it was a distributor rotor! which had a hairline crack. Another time ( maybe more like your case ) the Disco just wouldnt start. that time it was an ignition module. Both cheapish easy fixes but PITA to find. Hope this can help you. Cheers, Paul
nellie-mac,
Sep 4, 6:39pm
Oh Oh and also check the connection of the fuel pump ( under back carpet ontop of fuel tank ) to the wiring loom. this can corrode too. You should be able to hear the faint whir of the fuel pump if pump is ok
elect70,
Sep 5, 9:20am
Can hear fuel pump okif take fuse outstarts immediatley &it runs for20 secondsuntil i put fuse back in & restarts ok.Did a top end o/hshort while agonew ex valve& heads tested& gasketsnew plugstestedht leads etcruns well. Its definately fuel relatedhave adisc butno help . Did it atlights other dayrather embarrassing
gmphil,
Sep 5, 9:28am
Am wondring if u have relay fault and takin fuse out is tripin it back into play
bellky,
Sep 6, 6:09am
Leaking Injectors.
elect70,
Sep 6, 12:56pm
Well I have removed theseal plug & screwed in theidlemixture screw(theroeticallyleans it out) on throttle bodyidlesbetter& deliberatlly stalled itseems oknow
ceebee2,
Sep 6, 2:34pm
Suggests the throttle body is dirty.
nathan84,
Sep 6, 8:00pm
thers a thing inside the dash called a spider,it can do all sorts of crazy stuff,sits behind stereo might be worth looking at
steve56467,
Sep 6, 8:16pm
I was thinking something along those lines. Worn contacts on relay!
