I have a 1995 4x4 hilux diff i pulled out and its got 40 teeth,does any one know what ratio it would be
thunderbolt,
Sep 4, 2:33pm
How many pinion teeth!
gmphil,
Sep 4, 2:34pm
Should be stamped on the side of crown wheel
the-lada-dude,
Sep 4, 3:24pm
divide the No of pinion teeth into the No of crown wheel teeth and there's your ratioEG ; 40 / 9=4.444or 41 / 10=4.1you will usually find one of the gears will have an odd No of teethwould someone like to tell him why !
mokaubach,
Sep 4, 3:26pm
So the teeth mesh in a different place each rev.
the-lada-dude,
Sep 4, 3:39pm
good boytop of class for u my lad . suprising how many mech don't know these things
cuda.340,
Sep 4, 3:53pm
so when 1 pinion tooth breaks it can destroy each & every other tooth on the ring gear in short order of time.
mokaubach,
Sep 4, 4:21pm
Thats because they are trained to be spare parts fitters sadly.
the-lada-dude,
Sep 5, 5:54am
well,not sure how to answer that one, most people using shear logic would be flummoxed with that statement. surely a broken tooth is going to damage the whole unit anyway.
motorboy2011,
Sep 5, 6:00am
well at the end of the day, a gear with one smashed tooth is as useful as one with all the teeth smashed so really makes no difference.
the-lada-dude,
Sep 6, 8:20am
here's my logic, that one damaged tooth will have to try and bugger say 41 teeth as the gear set has odd No of teeth , where as even set , say 40/10 that one tooth will bugger 4 teeth much more quickly ,yes /no
