i know that the 98spec itr has better brakes and better factory headers and that, but what else is there to look into when it comes to the 2! and i havent heard much frm the 97spec range! is better then 96spec! as it dont seem as commen as 96/98 spec :)
vtecintegra,
Sep 25, 6:12pm
97 is still '96 spec'
The 98 update also got different gear rations, 5 stud wheels (16"), a different rear bumper and a much nicer airbag steering wheel (if it came with an airbag)
lazz323,
Sep 25, 6:19pm
yeah i knew about the 5x114.3 stud as apposed to the 4x114.3 , and airbags and cooler looking bumper but im mainly refering to the engine, internally are the cams the same! ecu much different! etc etc!
turton,
Sep 25, 6:27pm
engine the same. i have 97 type r and is same as the 96 spec. 98 spec is a bit better than the 96 spec mainly due to slightly larger brakes and nicer 16 inch wheels. Ecu, cams the same.
lazz323,
Sep 25, 6:34pm
oh right, just thought id ask anyways, but yeah the 98spec has the same exhaust sytem as well! should be slighlty quicker then 96spec correct! due to the headers are better ! (98spec larger and 4-1 design) (96/97 spec smaller 4-2-1 design) , also heard that 98 spec oem headers out perform a few aftermarket headers ! true or false
vtecintegra,
Sep 25, 6:37pm
The gearing makes more of a difference than the engine changes
turton,
Sep 25, 6:38pm
exhaust same except for headers. yes the 98 spec headers are very good but be carefull of scraping when lowering the car. yes they do out perform some aftermarket designs. Im not sure about which is quicker tho. 98 spec has airbags, bigger (and heavier) wheels, bigger disks so i reckon the 98 spec integra will be heavier. Iv driven/owned both and honestly cant tell the difference in power
lazz323,
Sep 25, 6:41pm
98 spec have longer gear ratios!
lazz323,
Sep 25, 6:42pm
guess what u say makes sense, more power but heavier, wonder what difference they have in poweroutputs on dyno! as the 96spec factory has 200BHP! same same for 98spec!
turton,
Sep 25, 6:42pm
both have 200hp.
vtecintegra,
Sep 25, 6:44pm
The low gears are shorter in the later cars, 4th and 5th are roughly the same
lazz323,
Sep 25, 7:03pm
isnt that a disadvantage in a way for 98spec to shift ealrier! cause 96 will still be in tec while the 98 has to change ! :P
vtecintegra,
Sep 25, 7:11pm
The shorter gears are an advantage on a car that makes power like an ITR
