Integrated turn signals
michael126, Sep 23, 5:46pm
looking about buy some for my motorcycle but have heard that we are not aloud them over here! does any-one know for sure! thanks
budgel, Sep 23, 7:25pm
I dont know what they are. Can you explain please!Integrated with what!
lookoutas, Sep 24, 3:59pm
Does the bike have 2 of those lights, so one can flash, as per Yankee cars!
Or does one half of a single light flash! That could be tricky to get past.
berg, Sep 24, 4:33pm
Reason for rejection in VIRM, a light has been modified and when you look into "modify" it says to pretty much change anything from origional
sparkles_bc, Sep 24, 4:42pm
I have a similar set in my Yammy, as long as the visibility angles meet the requirements then it shouldn't be a problem (45degrees outboard!)
michael126, Sep 24, 5:49pm
cheers, mighty just put it on take it for a wof if all else fails put the old ones back on. thanks again
motorboy2011, Sep 26, 11:26am
followed a bike with these today, not the easiest to tell which way its indicating as the indicator was so close to center of the light. Also, seeing its an LED setup, it flashing faster than normal didnt help
