Misfire 5 weeks after purchase
pbsrb5, Sep 23, 3:57pm
Hi All,
I bought a used car from a dealer 5 weeks ago. I had to wait for delivery because the dealer said the car had a running fault that was diagnosed as ht leads and would get them changed before i had the car. 5 weeks after delivery now and the fault has got worse, misfire is way worse thanbefore and when it misfires the temp gauge drops. I told the dealer about this ( and another fault 2 weeks ago ) and he has not called me back as he said he would. I will try again tomorrow, but I'd be interested in your thoughts - Full refund or should I be content with having the car repaired!
The car is a 2003 VW Golf.
thanks
hydraline, Sep 23, 3:59pm
You are at fault!No body sane would consider buying a VW used or new
sw20, Sep 23, 4:06pm
The dealer has the right to repair in a timely manner under the CGA. Return the vehicle to them.
kazbanz, Sep 23, 4:42pm
Here it is in black n white for ya
18 Options against suppliers where goods do not comply with guarantees
(1) Where a consumer has a right of redress against the supplier in accordance with this Part in respect of the failure of any goods to comply with a guarantee, the consumer may exercise the following remedies.
(2) Where the failure can be remedied, the consumer may??
grangies, Sep 23, 5:38pm
Is that why VW hovers around the top 3 car makers!
intrade, Sep 23, 6:01pm
probably another vw that was never serviced . you change leads and plugs , and there probably is a faultcode stored as to what plug had a missfire stored on the obd 2 system. Nothing wrong with Vw as long as they are serviced correctly. just say its a automatic on top of it. because thats the next thing that would not have seen a service
pbsrb5, Sep 23, 6:37pm
Full service history.
lyonruge, Sep 23, 7:03pm
Sounds just like a golf.
intrade, Sep 23, 8:43pm
serviced by whom!
remap, Sep 24, 4:57pm
More than likely coil packs on the golf. Give us a yell we can diagnose and fix for you pretty easy, for the sake of a hundy or so the dealer should just do it, but we can always bill the dealer if they agree.
unbeatabull, Sep 24, 5:34pm
Let them diagnose it first and then depending on what it needs as to your next course of action. If it is going to be major and a lemon you would want them to contribute or repair under their cost, or possibly look at getting a refund or different vehicle.
I'd be guessing coil packs as well, although Im curious as to why the Temp gauge moves at the same time.
Could also be EGR or a code stored in the system. Have had an EGR fail before on one, and replaced it and still same symptoms. Turns out had to go to a VW Dealer to have the code cleared and the EGR system Re-learned/calibrated before it would go back to normal.
