Rings and bearing price?
tinac, Sep 19, 6:31pm
Ballpark figure to replace rings and bearings in a 1998 mitsi chariot! Thanks :)
intrade, Sep 19, 6:32pm
smoking huh!
morrisman1, Sep 19, 6:34pm
at a guess, $2000! Remember when you go that deep, its never just rings and bearings. Its everything like timing belt, water pump, tensioners, clutch maybe, oil, coolant, head gasket, valve stem seals, hone the bore, and rebore oversize with new pistons if necessary.
tinac, Sep 19, 6:34pm
Yes, and loss of power and using heaps of oil
intrade, Sep 19, 6:35pm
if the engine is rooted then the boors will be eggshaped and you cant just add new rings. your then probably better off to replace the engine or biff the car.
mugenb20b, Sep 19, 6:35pm
Buy a new car, and not another GDi Mitsi thing.
morrisman1, Sep 19, 6:39pm
its gotta come down to whether you think its worth dropping a heap of money on the car. Are you going to get your money's worth out of it! is the rest of the car in good condition! does it have any other possible major jobs needing doing!
tinac, Sep 19, 6:41pm
Yeah we are tossing up wether to buy anew car instead. Rest of the car is in pretty good condition but we do need 2 new tyres for next warrant
intrade, Sep 19, 6:43pm
manual or auto and what engine!
franc123, Sep 19, 6:52pm
Those things are dangerous vehicles to start throwing cash at when they are too old, you will just get all that done and then the trans will blow and you are still left with something worth nothing.Seen it time and time again. Bottle of stop smoke and $1 reserve and put what you get towards a decent car.
snoopy221, Sep 19, 6:55pm
ball park MILEAGE!
Generaly up around 140 to 160,000 a set of protecs and valve seals and ya sorted.
But at 400,000 well-rebore and new pistons.
So sorry you tell US the RIGHT things and .
snoopy221, Sep 19, 6:57pm
Those things are dangerous vehicles to start throwing cash at when they are too old, you will just get all that done and then the trans will blow and you are still left with something worth nothing. Seen it time and time again
But again the automatic.and notthe manual
franc123, Sep 19, 6:58pm
Wrong, my comment applies to both transmissions, manuals are not quite as bad but they still fail.
snoopy221, Sep 19, 7:04pm
mmmmmmmmmmmmmmmmmm
Well in total honesty the manuals were a bit of a factory rodent special with taper roller bearings and insufficient caqsing strengthening webs to maintain preload
I M H O
And a time consuming assemble with solder and check crush and shim preload bearings accordingly to rebuild them correctly-
However the automatics!
mmmmm well um.
Oh did i forget the 3rd gear vacuum switched to become fifth and the speed sensing vacuum problems!
franc123, Sep 19, 7:07pm
You know a bit about Mitsi transaxles then!Good on ya.
NZTools, Sep 19, 7:08pm
Thanks for that. I've just managed to stop having nightmares about mitsi box's, now its all coming back again. lol
Or was that Mitsi's box! lol
snoopy221, Sep 19, 7:12pm
L M A O
Incedentaly one day i had a customers dash speedo cluster out and apart.
Back in 100 K buzzer removal jobbie days.LOL
Damn turd depolished itself and lost fifth-
Turned out one slightly longer screw should have been fitted where a slightly shorter one ended up.
[Doncha just hate it when that appens-LOL]
NZTools, Sep 19, 7:14pm
Yeah, and the hours spent scratching your head wondering what the fluck you had done to cause it. lol
snoopy221, Sep 19, 7:15pm
Nah mate it was the length-and how ya screwed it-LOL
tinac, Sep 19, 7:39pm
Auto, 2.4l(I think) and 200,000km
NZTools, Sep 19, 7:42pm
Haha. Same applies to mitsi's box.
Anyway, must go get some sleep. Big day tomorrow.
Off to CHCH to see the Wiggles.
Toot Toot Chugga Chugga Big red car.SLAP!
mugenb20b, Sep 19, 7:47pm
200k! Sorry to sound blunt, but she's done.finished.as in, don't spend any more money on it. Buy a 2.4 litre, well serviced Toyota Ipsum.
phillip.weston, Sep 19, 9:31pm
bores will be fine on that engine as they are on all Sirius family Mitsubishi engines. Can guarantee it will be the oil control rings gummed up due to blocked oil drain holes in the piston skirts. Enlargen the holes, fit new rings, give the bores a quick hone and you will be fine.
Plenty of well serviced Mitsubishis doing over 200,000kms with no issues. My turbocharged 21 year old Galant with the smaller 2L 4G63 engine is on 200,000+ kms and no issues.
skyblue17, Sep 20, 1:16pm
TA.confused yet.!
mrfxit, Sep 20, 5:44pm
LOL oh dear, mamma mia
