Hi went to put my trailer for first time on my new car ant it wont fit its too big. Are there common sizes for normal 6x4 trailers thanks.
daryl14,
Sep 18, 6:14am
There are two different sizes: 1 7/8 inch (47 mm) and 2 inch (50 mm). Just go to repco and buy the other size tow ball. You'll need a pretty big spanner to undo the nut. Make sure the Shank (thread) is the right size too as they have different sizes also. 1 7/8 is the most common in nz.
inkapuka,
Sep 18, 6:23am
Yeah the trailer has those numbers on it the towball is still brand new lol its from ozzy commodore so maybe thats thier common size
gmphil,
Sep 18, 6:27am
1/7 is normal size 50 mm is used more for heavyer trailers like tamden braked trailer
skin1235,
Sep 18, 9:21am
whats too big! the trailer coupling or the towball on the car, there are many standard light trailers with 50mm couplings cos I'm not sure after reading what you wrote just which part has what written on it, either way it will be a simple change the ball to suit
jokerboss,
Sep 18, 9:54am
I like the trailer hitches that accommodate both sizes, you just flip the handle round and the internal coupling takes care of size irregularities : spare towball is simplest option
inkapuka,
Sep 18, 12:57pm
The ball. Is too big for trailer sorry I even confused myself Just realised What wrote it was early Lol
elect70,
Sep 18, 1:05pm
I though1 wasimperial & other metric.
peril787b1,
Sep 18, 4:12pm
They are, one is 50mm (metric) and the other is 1 7/8" (imperial)
lookoutas,
Sep 18, 4:23pm
Now you're confusing things - go back to the first line of post #2. Those are the 2 sizes in imperial & metric.
jmma,
Sep 18, 4:30pm
So there is two sizes, big balls and bigger balls (o:
Sep 18, 4:50pm
50mm is european size
peril787b1,
Sep 18, 5:12pm
Look at a tow ball at some stage in your life. One is stamped 50mm the other is stamped 1-7/8". By this simple act of using your eyes, you'll see that one is known as a metric size and the other is imperial. I'm yet to see a "47mm" towball anywhere.
elect70,
Sep 19, 1:38pm
Seen plenty wihout markings.
skin1235,
Sep 19, 1:45pm
plenty with 2" markings too, and the 2 1/2" one I have here
50mm is 2", immaterial if metric or imperial
light trailer was 1 7/8 heavy trailer ( tandem behind private vehicle) was 2" heavy trailer ( single or tandem behind truck or tractor) was 2 1/2 pre the days of ringfeder or the like drop pin couplings - back then trailers were limited to 6 tons gross ie about 3 ton payload
redhead96,
Sep 20, 11:36am
There is no size to them when you walk in to them
skin1235,
Sep 20, 4:38pm
described as 6ft 4" frizzyheaded huge muddafoker when explaining your injuries at A&E!
