Tie Rod / Rack End Removal Tool
nzsilverwolf, Sep 17, 2:42pm
Hey guys, I'm wondering if anyone has one of these that I can borrow.I'd be forever grateful and in return can offer a little money or computer services.
Please email me if you're interested josh at virtual-wolf.com
intrade, Sep 17, 2:45pm
um you use a hammer and chissel to get the savety plate bending back. then you use a big mother plumbers wrench and screw them off . and we are not alowed to make contact on here or your tradme account will be deleted by the staff.
thats the mother you need
http://www.haustechnik-express.de/images/ERZS40.jpg!osCsid=ff04536375e8bab99da8de209dc9a5b4
intrade, Sep 17, 2:47pm
to put em back on you can do the same or use a spanner when it fits . the above is for a rack-and pinion from toyota , no idea what your car is but my renault traffic had a similar screw in type thing used same plumbers wrench to crack em after removal of the savety latch
mechnificent, Sep 17, 6:40pm
Some people have a longish bit of two inch galvanised water pipe with a nut welded on the side at one end. You slip the tube over the rod, wind a bolt through the nut and the hole in the pipe that I forgot to mention, it's under the nut. The bolt jambs the tierod's nut thingy, then you poke a bar through the hole in the other end of the galvanised pipe(did I mention that hole), and you wind the rackendoff. One pipe fits most sizes.
scuba, Sep 17, 6:41pm
i would suggest the correct tool from BNT would be cheaper.and that it would be less likely to fall off if fitted by someone who knows what they're doing rather than op-
unbeatabull, Sep 17, 6:42pm
We have a great simple tool at work. Hard to describe, but its like a hoop you put over the rod, which has another bit that is on a hinge with grooved teeth in it, just put your extension/power bar in it and as you tighten it it squeezes the hoop & other bit together and turns and undoes it . really bad description, but its really simple and works ridiculously well!
incar., Sep 17, 6:43pm
no tool, try a pair of vise grips
mechnificent, Sep 17, 6:54pm
Sometimes there is not much room around the tierod end, then the tube thingy is handy. cheap and simple to make too, and you can use it on your powerbar if you are a rough bugger, or whack things with it, or slide it along axles to whack bearings on ,or. or. or.
supernova2, Sep 17, 7:12pm
Chain wrench will probably work as well if you are a rough bugger.I've used a stilson a couple of times on rack endsTrouble with that type of wrench is it will squeeze the joint out of round if you not careful.
hrt, Sep 17, 7:45pm
The proper pipe: http://buy1.snapon.com/catalog/OBJECTS/54500/54499.JPG
Available in many brands, very useful if you're doing a lot of rack ends. Hole in the end for a half inch extension/bar
unbeatabull, Sep 17, 7:52pm
Way more complicated then the tool we have!
snoopy221, Sep 17, 9:07pm
Ya KNOW if! ya done enuff of em-
Some of em ACTUALLY have a roll pin-locking pin that it sorta PAYS to drill out.
But hey.
The ole SIMPLE moi asks
Um scuse moi but what ve hikle!
mmmmmmmmmmmmmm
nzsilverwolf, Sep 19, 11:14am
Tis an AE111 98 Levin
