Who knows evo 1s well?
breandme, Sep 16, 5:07pm
just got one stock apart from full exhaust/ wastegate plumed in, and pod/bov. whats the best grade oil for this ! its high kms. and how many litres! its also running 15psi boost is this safe on a 93 4g63 thanks
evotime, Sep 16, 6:26pm
15 psi is fine as long as it isnt detonating, put a cold air box around the pod, prefill the oil filter when you change it, I used mobil 1 0w-50 from memory but it was free so.
Anyway high kms prossibly means its already had a rebuild.
I had my 2 for seven years sold it 4 years ago and still want it back enjoy
cdjtrading, Sep 17, 4:11pm
How many litres of oil do they hold !
evotime, Sep 17, 5:54pm
4 1/4 litres ish. More than 4 litres less than 4.5l, drain properly, prefill new filter,add 4l run ,stop, let it settle while having a coffee top up.
Easier to top up than try to drain a touch of you overfill it
cdjtrading, Sep 18, 4:12pm
thanks :) y do u need to prefill the filters on these! i gues the filter cant be filled to much, as it sits on its side ! not downwards
