So I have a new Mazda 6 2004, yay : ) It's all goodbut I'm not sure about 1 thing. when reversing the pedal gives a small clicking feel. Is this normal! Thanks
a.woodrow,
Sep 16, 6:25pm
Which pedal is clicking!
Sep 16, 6:25pm
what pedal! snap.
sunny_daze,
Sep 16, 6:26pm
Sorry the brake. No accelerator cause wouldn't be braking.
Sep 16, 6:29pm
automatic
sunny_daze,
Sep 16, 6:30pm
Yes auto
Sep 16, 6:33pm
dont know if its normal but should be enough info now for somone to tell if they do this.
sunny_daze,
Sep 16, 6:35pm
Thanks. It's only new and it has a 1 month warranty only so want to get onto it if it is a problem but never had a car over 97 so thought it might be something with newer models.
a.woodrow,
Sep 16, 6:50pm
If it is when you first start the car and put it in reverse, I would say it is the ABS self check. I've struck a few models that do this
sunny_daze,
Sep 16, 6:51pm
So a quick google seems to tell me my car is fine as it has abs brakes and they do this. i can't seem to remember which pedal is clicking but thinking it may be break now, our drive is long and narrow and I do break often thinking about it and this is when i'm feeling it. Would still appreciate other opinions though, thanks.
sunny_daze,
Sep 16, 6:52pm
thanks, yip always when first starting.
Sep 17, 9:11am
REPEAT AFTER ME -"I read both the front and back of the CIN card when I purchased the car". As such you will be aware you don't have a "months" warranty but are covered by the CGA for afair and reasonable lenth of time.That time is a bit ambiguous but is DEFINITELY a lot longer than one month.
r15,
Sep 17, 9:44am
i;d put my money one it being the brake pads moving on the caliper.
if you go forward, then brake then reverse then brake it will probably do it every time.
it's normal.
the_chooky,
Sep 17, 12:59pm
Or a caliper is loose and about to fall off.
supernova2,
Sep 17, 5:08pm
Or its got the wrong pads in it, or the hub caps loose, or or or or or or !
sunny_daze,
Sep 17, 5:47pm
Yes of course I did (5 mins ago) doesn't really say much but I get your point. Thanks.
sunny_daze,
Sep 17, 5:47pm
Thanks ???
Sep 17, 6:22pm
Hey no worries-sorry if I came across as sarky.
