Mean!
a.woodrow, Sep 26, 3:43pm
Some people think that using water for fuel would rust or somehow damage their engine. but guess what, youre already burn water in your engine . your current unmodified engine runs right now on hydrocarbons. Hydrogen is a component of water. the other component of water is oxygen which is ejected into the air intake. Thats hydrogen and oxygen are both being burned in your engine right now. But not bonded together as water . in our process, therere burned too. But as elements, that are also not bonded together as water. Youll not actually be burning water in your engine. Youll be burning hydrogen, oxygen, carbon and many other elements. And theyre gas or plasma state. For that reason you should no longer have to change your oil. Pure elements burns so cleanly the oil no longer gets dirty. Not having to change your oil regularly should dramatically increase the life of your engine.
un_known, Sep 26, 4:28pm
lol "How to burn water just by modifying spark plug and ignition system"
What a load of horse rot.Simple test get a glass of water and try to light it on fire. if u cant do that with a flame how is a spark plug going to do it.
thewomble1, Sep 26, 6:06pm
How is not changing the oil regularly going to dramatically increase the life of the engine!What happens to the metal 'filings' in the oil! Look at the magnetic sump plugs when you can the oil.
noswalg, Sep 26, 6:13pm
Wow that listing was pulled quickly
johnf_456, Sep 26, 6:23pm
Gone
