Help removiong Rodeo headrest.
brokebloke1, Oct 7, 2:50pm
I think you just keep pulling them up arnt they spring loaded catch!
dutchess46, Oct 7, 2:54pm
They go up and down several notches to adjust but dont seem to come right off. Have applied quite a bit of pressure upwards with no luck. Dont want to wreck them.
andy61, Oct 7, 2:56pm
Just pull the seatcover overthe headrest,come off easy enough without removing the headrest.I pretty sure you have to hold a clip out(inside the seat) as you dismantle the seat to remove the headrest.
dutchess46, Oct 7, 2:59pm
Slot in cover is not big enough to get over the headrest so they must have been off when the covers were put on.
dutchess46, Oct 7, 6:44pm
Must be some Holden buffs on board tonight.
NZTools, Oct 7, 6:47pm
Nah.Theare all rushing out to buy a new jacket after the win today.
treachug, Oct 7, 7:14pm
Looking at the photo, I'dsay they have an internal clip to hold the shafts in. Short of putting your hand up the inside of the seat trim & removing the clip (thats a mission & a motor trimmer job), forget it. Remove them another way like mentioned above
gunhand, Oct 7, 7:19pm
Ive come across this before but trying to remember how it worked, was simple in the end though.Are you sure theres no button or slide knob anywhere. Try pushing it all the way down then pull it up again in one go.
Do either of the plastic surrounds twist at all!
barry93, Oct 7, 8:50pm
mate theres a button you push and you need to push it dam hard on ours.its at the back of the seat on the outer pole area i think.
dutchess46, Oct 7, 9:24pm
Thaks Barry93. I will give it a shot in the morning.
dutchess46, Oct 8, 12:20pm
Update. None the wiser.
Managed to force the cover over the headrest so problem solved.
Couldnt find any hidden buttons. Took it to the local Holden dealership. Several helpful guys but none managed to get them off. Thanks for the suggestions.
kevlight, Oct 9, 8:42am
kevlight, Oct 9, 8:45am
kevlight, Oct 9, 8:55am
There is a sliding spring loaded clip on the back of each headrest stem located under the plastic ferrule. It is difficult to find at first but but you will be able to feel it as you move the headrest up and down.There are two different ways in which to remove the headrest:
With a screwdriver
With your own hands
guest, Dec 30, 7:17am
Is there a video on the net somewhere???
