400 cleveland wont go
frog68, Oct 5, 3:58pm
400m Cleveland motor help have but a new timeing chain set on my motor and now it wont go i truned the motor over till the key way in the crank was lined up with the dowel in the camshaft sliped the old timeing chain set off with out moveing any think lined the new set up sliped on and every think lined up but cant get motor to fire so took a plug out and earthed the plug on the motor put no spark but pull the plug away about 15mm and get spark off the end of the plug and the motor any help as to what i have done wrong wood be good thanks
moparpete, Oct 5, 4:45pm
Have you timed #1 cylinder to fire at TDC with dizzy. Your timing sounds out, so go back to basics and get that right. You know you have spark, but she won`t go when its outta whack.
40wav, Oct 5, 6:26pm
The plug you tried might be rooted! If so, that will only be part of the problem by the sound of it. Do what moparpete says, then go from there. Does it have a new set of plugs!
kaspas, Oct 6, 5:05am
make sure its tdc on the VALVE stroke not the exhaust stroke
lookoutas, Oct 6, 5:57am
Was it going before you tutu'd!
Might pay to check the dizzy drive pin. Just grab the rotor and see if it turns more than you think it should.
Give jason a call - it's going to happen to him soon!
whqqsh, Oct 6, 5:59am
Midland motor was a bit of an oddball but all the Clevo basics apply re timing etc
kiwisparky, Oct 6, 7:14am
its a ford lol
splinter67, Oct 6, 7:16am
The dizzy is at the wrong end of the motor
jason18, Oct 6, 7:51am
Hahha shut up! I have no timing chains. Mines gear driven :D
petermcg, Oct 6, 7:58am
Hey the spark thing sounds a bit strange, might be an earth or the dissy polarised wrong maybe.
jason18, Oct 6, 10:15am
I dont know how many times I have heard this! Should we drill it into the back!
lookoutas, Oct 6, 11:48am
Only a dork would do that.
chebry, Oct 6, 12:49pm
Gas, Spark, Compression all 3 needed at the right time then it should run
splinter67, Oct 6, 1:00pm
It will make it go better lol
andrewph, Oct 6, 1:06pm
There is gas in the tank isnt there!
jason18, Oct 6, 1:11pm
True Story!
jason18, Oct 6, 1:24pm
What do I cover the front hole up with tho! Or run it twin dizzy
jmma, Oct 6, 1:26pm
A big cork (o:
splinter67, Oct 6, 1:38pm
that might give you a much needed dose of horsepower lol
jason18, Oct 6, 3:25pm
Oh mint good idea!
splinter67, Oct 6, 3:28pm
well had to let you catch up somehow lol
extrayda, Oct 6, 3:49pm
When I had Ford V8s I always liked the idea of the dizzy at the back (mainly cos it's tidier !).When I had Chev's I missed the ease of getting to the dizzy at the front. 351 Cleveland and 350 Chev I rate as equals :-)
extrayda, Oct 6, 3:54pm
As above - is the timing right!
Also strange that the plug didn't spark when you earthed it, but did against the block!
- Was the motor running OK before the chain was done!
- Are you SURE you have the leads in the right places (if they were taken off).
- Is the engine properly earthed (cable from battery to engine), or just earthing through trans/other stuff. (assuming here from memory that Ford blocks should be earthed directly, I know my chev did some odd things if it wasn't).
frog68, Oct 6, 6:41pm
ok guys thanks for all the help it is now goingabout 12 weeks ago i but a new set of spark plugs in and wasrunninf fine till i changed the time chain set after i done that it woodnt go so today i but the old plugs back in that came with the motorand she fired up on the frist trun of the key
extrayda, Oct 6, 7:08pm
Strange. were the new plugs the correct type! Did you gap them (although would still expect it to run without that).
Anyway, good news that it's up and running again.
