awesome drive by Whincup but a ford on pole, brilliant. let the fun begin tomorrow
clark20,
Oct 6, 5:16pm
Thats what I miss from the old TV days, we used to get warmed up on the Saturday
fordmfp,
Oct 6, 5:20pm
Woohoo 3 FORDS on the front 2 rows!
fordcrzy,
Oct 6, 5:24pm
TV3 coverage SUCKS, and the fact that we are blocked from watching the streams from fox and V8 live is a disgrace. if they wont even broadcast it then let us watch it on line
fordmfp,
Oct 6, 5:40pm
I watched it on v8 live mate, It was the proper coverage too not in car stuff
fordcrzy,
Oct 6, 5:54pm
how did you get V8 Live! do you have an ip blocker or something!
wotz_it_2_ya,
Oct 6, 6:23pm
When you register use an aussie address and post code.
marywarren,
Oct 6, 6:24pm
I watched a 3 hr broadcast on Friday and have just watched 5 1/2 hrs today from a satellite feed. Tommorrows big race will be live and ad free. I don't know why you complain about TV3s coverage when theres other alternatives.
fordmfp,
Oct 6, 6:39pm
No ip blocker mate just signed up and there was nowhere to put nz so i put a state over there and have never had any probs
fordmfp,
Oct 6, 6:40pm
Do you have your satellite pointed at a different satellite! Do you use your computer!
stockyz,
Oct 6, 6:46pm
. I've noticed you saying the same thing in every thread about the v8s,but whenever someone asks you a question myself included about how us non tech mere mortals can view said races live there is no help coming
fordcrzy,
Oct 6, 7:10pm
i registered using a sydney postcode and i cant get the v8 live feed! just a re run of last years race.
phlippy,
Oct 6, 7:17pm
Our flat has acquired an old sky dish with a Sharp LNB, have set it up on the deck and got it going and tuned into Optus D2 Problem we got is we're trying to pick up the V8 Supercars feed back having plenty of trouble. I'm using an Ultraplus 980hd, have done a Blind Scan of the satellite and picked up nothing on 12679 V using an SR of 6700. All the other (mostly) non-english channels came up fine, and getting a signal of around 80%
I've tried playing around with the S/R and even tried manually entering the PIDs but still getting nothing. Anyone got an ideas! ---- Try 12680 V 6670 1165/1125/1165 comes up as V8 world ---- Now I got it going, the problem appeared to be the internal TP setting in the ultraplus software was wanting it to be on a S/R of 6700, when I tried typing in 6670 I think the box was using the original S/R
splinter67,
Oct 6, 7:18pm
go to justin tv then use pigboy 05 He has a live feed
splinter67,
Oct 6, 7:22pm
so where do I stick my screwdriver can you explain that in Englishthanks
fordcrzy,
Oct 6, 7:23pm
i was watching the justin feed but the quality is rubbish on a 46" tv
marywarren,
Oct 6, 7:25pm
Yes thats right. Its called doing your home work and searching google as I had to do. All stuff can be got off TM. You will need, a dish and an lnb, an HD Satellite STB (learn how to use, scanning or adding transponder numbers into it), point it at satellite D2. There are plenty of FTA satellite sites out there to use. The rest is up to you.
phlippy,
Oct 6, 7:26pm
Optus D2152°E Optus D2launched September 2007. Optus D2 providingbroadcast services for direct to home television broadcasting services to Australia and New Zealand Optus D2 will provide capacity for growth. Optus D2 Satellite Technical Information Satellite Satellite Type:Orbital Sciences STAR-2 Launch Mass:2,460 kg Mass in Orbit:1,160 kg Stablization:3-Axis Dimensions:4.0 metres height; 21.4 metres with solar arrays deployed Transponders Operating Band:Ku FSS Uplink Frequencies:Ku FSS: 14.0 - 14.5 GHz Downlink Frequencies:Ku FSS: 12.25 - 12.75 GHz Number of Transponders: Ku-Band: 16 @ 125 W, 8 @ 44 W FSS Bandwidth:54 MHz Ku Band Polarization:Linear Performance EIRP:Australia: 44 to 52 dBW New Zealand: 51 - 57 dBW Australia/New Zealand combined: 43 - 55 dBW G/T:Australia: 0 to 5 dB/K New Zealand: 1 to 10 dB/K Australia/New Zealand combined: -2 to 5 dB/K SFD:-78 to -98 dBW/m2 Solar Array Power:6,440 Watts Telemetry:Ku-Band Command:Ku-Band
fordmfp,
Oct 6, 7:30pm
The live feed will only show while its on mate and when its over they just play replays, Lately theve only shown in car footage when the races are on but the qual and top ten were both tv coverage which was awesome!
marywarren,
Oct 6, 7:36pm
Good to see someone working it out. The ultraplus are easy to use. You put those numbers in manually so it would of searched just that.
