Are you sure your checking sensor 1 and not a post cat sensor. Have you tried performance testing the sensor! induce a fault or air leak and look for an expected response, pull the dipstick etc and observe the reaction, this wil at least tell you if the sensor is reacting as expected
fordcrzy,
Oct 18, 7:20pm
600 for an O2 sensor! you must be joking! lets face it.its probably just a 4 wire heated o2 sensor.
fordcrzy,
Oct 18, 7:26pm
a bosch LS06 sensor would probably do the trick.double check it though
If its got one of those boat anchor QD25DE engines in it, that among other things causes the ECU to have a spazz because of the cam/crank angle sensors going out of sync because of timing chain stretch, you might have an injector not shutting off properly, O2 sensor codes or odd readings from them are the giveaway.They aren't serviceable and the whole fuel rail needs replacing with it.$$$$$.
justcruisin,
Oct 18, 9:14pm
I'm heading to auckland to pick up a front guard after some idiot backed into the front of me and had plenty of room, if you would like to borrow 1 for the day I have a velleman hps10,just a thought
justcruisin,
Oct 18, 9:37pm
no prob, all my diagnostic gear just sitting here at the moment till i have my neck fusion next week, god i hope it works, all the best with ya repairs
laneyjan,
Jan 3, 9:19pm
HI justcruisin this is a professional thread and Im one too in another field.your neck fusion needs all the help you can get so i am praying for you that it will go well for you.you could say one for yourself too.I see you mention Him. kind regards Lany
