Inflatable pool on deck.
bjdw, Oct 18, 5:43pm
So, I was thinking about getting one of those inflatable pools, 3 meter diameter holds nearly 3,000 litres of water.Will it break my deck!
(I'm putting this in here because a lot of tradies are car enthusiasts)
Cheers.
intrade, Oct 18, 5:46pm
well a liter is a kg so its 3000 plus the humans inside the pool and the waight from the pool it self. I would say not wise . unless you got a ultra strong deck its like stacking 2 cars on top of each other with people inside on your deck.
andrea_w, Oct 18, 5:46pm
That would depend entirely on how the deck is constructed!
Don't forget, 1ltr of water= 1kg. Full, that pool will weigh 3 tonne
.or do you mean the deck of a ute lol
gammelvind, Oct 18, 5:48pm
Can your deck carry 3 tons! Bit hard for anyone to work out whether it will work as you haven't described your deck.
I guess you have a concrete deck painted green!
intrade, Oct 18, 5:56pm
well you probably want a few plywood sheets. and if it brakes you got a reason to rebuild it
jmma, Oct 18, 6:01pm
Yes to adding ply sheets (o:
bjdw, Oct 18, 6:01pm
If it breaks, I'll just make it look good with a few nails and a bit of gorilla glue, then it'll be the next tenants problem ;-)
jason_247, Oct 19, 6:44am
keep in mind the bigger pools must conform to the fencing act BS
i know its mostly stupid but we all know what the media will do if a kid sneaks in and drowns
gadgit3, Oct 19, 7:56am
Yea it will handle it easy. Looks to be just bearers on the ground and decking timber over the top.
mrfxit, Oct 19, 8:14am
Correct.
1ltr water = 1KG
PLUS it's a moving/surging mass so will push the deck sideways as well as downwards force PLUS . humans
mrfxit, Oct 19, 8:15am
Yep, sit some ply sheets on there 1st, then poly sheets over that to protect from sharp edges.
bill-robinson, Oct 19, 10:38am
what are the ply sheets going to do! the load is already spread by the pool floor over the same area.
jmma, Oct 19, 11:03am
Bracing (o:
jmma, Oct 19, 12:03pm
Brace it from side ways movement, like you brace a wall (o:
fordkiwi27, Oct 19, 12:49pm
not over the whole area. it would just be stronger with ply i think!i dunno im just a painter:)
mechnificent, Oct 19, 12:54pm
If the pool is 300 mills deep, the pressure/load will be 3 kilos per 100 mm square. should handle it easily I'd think, given that it looks to be built on the ground. Put a bucket of water on the deck and see if it falls through the planking.
elect70, Oct 19, 1:36pm
Ply will give it smoth surface to prevent tears /punctures,needs fence on other 2 sides & councilconsentmore $$$
mrfxit, Oct 19, 4:11pm
Yep bracing.
As a deck, it's all slates
With the ply sheets, it'sa single slab
mechnificent, Oct 19, 6:40pm
Aren't shallow pools exempt!
And if it does need a permit and fence, I think that fence that is there won't qualify. I think it has to be climb proof, which that one probably isn't if it has horizontal rails on the other side.
gemini_gurl, Oct 19, 7:33pm
Anything deeper than 40cm high, and lower than 1.2 metres (I think that's the height) requires fencing.
splinter67, Oct 19, 9:03pm
Nah should be all good can I watch when you fill it up and do you mind if I video it!
bill-robinson, Oct 20, 4:55am
As you were, sorry I did not see the photo of the deck.
elect70, Oct 20, 1:56pm
Councilshire chopperoccasionally & surveytheirterritorylooking for unfenced pools . .
andrea_w, Oct 20, 2:10pm
It's not a pool. it's an oversized beer chiller, right!
