What's the best mag cleaner get a lot of break dust build up on wheels and It's a pain to get off
trdbzr,
Oct 14, 8:02pm
Sometimes it digs right in and is near impossible to take off. Is it alloy wheels! And how bad is it!
sidewayz3,
Oct 14, 8:08pm
Yeah alloy wheels front ones are bad wont get it all off but back one just had Resurfaced so just need a good clean ( m sport BMW wheels)
trdbzr,
Oct 14, 8:23pm
The BEST non-acidic alloy wheel cleaner is made by Sonax. Its called Xtreme Wheel Cleaner. Next best thing would be to clay bar the wheels and see if that helps. And be sure to wax your wheels after you're done cleaning it. It will stop the brake dust getting ingrained into the wheels and will make cleaning it off a breeze. The key is to actually clean them as often as possible.
sidewayz3,
Oct 14, 8:29pm
Ok thank you I will look for it thanks for ur help
daryl14,
Oct 14, 8:29pm
Take your wheels off if using the spray can Mag cleaners, or they will stuff your brake pads.
chook90,
Oct 14, 8:51pm
There is a product called Iron- X which is sheer brillance at removing brake material from wheels, particularly anything that traditional mag cleaner wont touch. Spray on, soak at it lifts of with a stiff brush. DONT attempt to do this on the car. Once clean use a sealer to prevent brake duct sticking as much.
cowlover,
Oct 14, 10:08pm
Best thing I've found was a brushless car wash machine.Thewheel bit is like a rotating waterblaster.
mike77,
Oct 15, 2:58pm
Oven cleaner, I had my wheels off at the time, cheap as.
whqqsh,
Oct 15, 3:38pm
was at washworld a while ago & the guy gave my wheels a squirt with a citrus type cleaner, they looked great
thejazzpianoma,
Oct 15, 4:25pm
If you use your clay bar on your wheels do not use it on your paintwork again.
I demote my clay bars from paint to glass to wheels in that very specific order.
racetoy,
Oct 16, 6:46am
im a car valeti use supercheap degreaser in the purple container .brilliant stuff, spray it on water blast it off then just buff with soft cloth or if real stuborn use nylon non scratch pad and autosol
