Winch
gerda4, Oct 11, 8:37am
how fast does a 12v winch go!
splinter67, Oct 11, 8:53am
I got passed by one this morning it was doing at least 120
grangies, Oct 11, 9:36am
The voltage is just the electricity supply.
The speed of the winch all comes down to the gearing of the winch.
Many have more than one speed.
horsygirl, Oct 11, 1:30pm
24V will make it go twice the speed.or 6V if you want to slow it down.
horsygirl, Oct 11, 1:34pm
or if you want it super quick plug it into a 3 pin plug or if your game for for a real fast ride try 3 phase @ 440V.
solarboy, Oct 11, 10:43pm
No, the escaping smoke will stop it promptly.
whqqsh, Oct 12, 4:59am
I always keep a refill can of smoke just in case some comes out
fryan1962, Oct 12, 6:23am
Can I ask what you are trying to achieve! it does come down to gearing
chebry, Oct 12, 7:02am
Quicker than a hand winch
gerda4, Oct 12, 7:13am
im trying to make a go cart and looking at other projects ive seen people use winches so i thort i could use one, what would be the best 24v or 12!
fryan1962, Oct 12, 4:13pm
12 voltyou might get old mobility scooter
but that is not winch, more just an electric motor
rob_man, Oct 12, 6:28pm
I have seen a generator used as a motor on a go cart, winch motors are very similar to starter motors so one of those may work if you take off the pinion.
treecave, Oct 12, 6:35pm
suck a lot of power though. mobility scooter motor would be best but dont expect a lot of speed out of it though.
treecave, Oct 12, 6:38pm
24v would need 2 batteries if weight will be an issue. higher the voltage the less amps drawn. that determines battery size (capacity) to a certain extent.
40wav, Oct 12, 7:18pm
Best would be petrol. Many more options that way.
gerda4, Oct 13, 12:15pm
if i decied to use a lawn mower motor how would i go about that
rob_man, Oct 13, 1:22pm
A chainsaw motor is quite simple to use, it already has a centrifugal clutch and I think you can drive a chain off the existing sprocket. A 50cc scooter engine is also worth considering.
gerda4, Oct 15, 4:59pm
with that motor you have to add that shaft thing. unles there is a better way of doing it
NZTools, Oct 15, 7:00pm
Any gokart will have to have shafts etc added and chains or belts to transfer the drive from the engine to the rear wheels. The is muchmore to it than bolting an engine to a frame and hopping on for a ride.
