hey guys, I have a welding job to do but need to first clean grease off both surfaces, open to experiences / opinions!Cheers
red97,
Oct 13, 9:20pm
i find that a quick going over with a grinder gets rid of grease and leaves a good welding surface
hijacka,
Oct 13, 9:35pm
Brake clean then grinder
virago72,
Oct 13, 9:36pm
what about carb clean!
purple666,
Oct 13, 9:36pm
What are you welding! What are you welding with!
cuda.340,
Oct 13, 9:37pm
don't use brake clean, it gets into the porous cell structure of the steel & when you weld it emits a toxic fume thats very bad for you. there was a big thing about this earlier this year. use carb cleaner instead or white spirits.
virago72,
Oct 13, 9:39pm
welding steel, arc welder.
purple666,
Oct 13, 9:42pm
A grinder will get it clean enough for arc welding, you only need a light pass with it.
austingtir,
Oct 13, 9:49pm
clean off then burn it out with a torch.By far the best way as it always works.
virago72,
Oct 13, 9:56pm
ok, but clean off with what! before burning off! cheers
red97,
Oct 14, 7:32am
unless it is literally covered in half an inch of grease and you are welding a nuclear reactor core or something equally critical i have always found that as soon as the weld is started the grease burns off well before it has a chance to interfere with the weld, wipe it grind it weld it
austingtir,
Oct 14, 7:33am
A rag just get the majority of it of then burn it off
mrfxit,
Oct 14, 7:39am
GRINDING GREASE . LOL yea whatever . mostly just heats it up a smears it all over the place Degreaser / Petrol / Kerosene / turps depending on what you have available & the type of grease then simply hose off with water. Do your grinding & welding after that.
h.e,
Oct 14, 8:05am
depends what it is if its a grease covered quick hitch i will steam clean it before i start.if its a stuck bearing shell that you are running a weld around to shrink it a quick wipe with a rag will do.otherwise i generally wipe it with a rag, burn it off with the gas,quick grind and your into it
lookoutas,
Oct 14, 12:06pm
There's stuff out called Grease & Wax Remover! It's good for cleaning up every other thing that could be covered in greasy stuff. Then there's another product out called Wax & Grease Remover, but that all depends on what you wanta remove first and foremost.
Or just turn the power up.
clampits,
Oct 14, 12:14pm
NEVER USE BRAKE CLEANER!Read This linkhttp://www.brewracingframe- s.com/id75.htm
Thats pretty bloody serious, and would be a very easy mistake to make. This should be a warning in its own thread. Will someone do that!
hijacka,
Oct 14, 5:08pm
What a bloody stupid thing to suggest! Get some brains man!. Oopps is that me! DOH!
johnf_456,
Oct 14, 5:34pm
Go on post 19
hijacka,
Oct 14, 5:43pm
Scary thing is i've used brake clean before welding as its easier to spray and walk away than get thinners and rag etc Now i know better! cheers
austingtir,
Oct 14, 6:22pm
I weld every day on oil,greece and paint covered parts trust me guys just use a damn torch dont mess with this other crap.
40wav,
Oct 14, 6:24pm
Alright then. Not quite sure how to post Jazzs link but I'll give it a go.
skin1235,
Oct 14, 7:03pm
jeezus, thats a horror story
I actually got out of my chair and checked a can of cleaner I use regularly
good ole supercheap Australian Export degreaser - had to go online to find the actives - not listed on the can appears itis 60 % white spirits, sigh of relief - but then this popped up
"Hazards Category: This product is hazardous according to the criteria of the NOHSC. Classed as a Schedule 5 Poison according to the SUSDP. Classsed as UN1950 Class 2.1 Aerosol. All components are listed on the AICS. Risk Phrase(s):
R36/37/38 Irritating to Eyes, respiratory system and the skin
R49: May cause cancer
R65: May cause lung damage if swallowed
R66: Repeated exposure may cause drying and cracking of the skin.
WARNING: Inhaling concentrated vapours (???chroming???) may prove fatal.
Safety Phrase(s): S2: Keep out of reach of children S14: Keep away from heat, ignition sources and oxidisers S23: Do not breathe vapour S24/25: Avoid contact with skin and eyes S36/37/39: Wear suitable protective clothing, gloves and eyeface protection."
that one is already in the wheelie bin
water blaster and wire brush has got to be a option
skin1235,
Oct 14, 7:06pm
chroming is the vapor coming off a hot exhaust, or the piece I'm welding after giving it a clean and wipe - and thatscommon occurrence
