Just brought another amp now 2 amps how to setup?
inkapuka, Oct 25, 4:24pm
Ok ive got the 2 channel 400 wat amp currently running the 1400wat dual coil sub, now ive just purchased a 800 wat amp4 channel ,and have some 6x9's i want to use how will i go around setting it up thanks
sparkles_bc, Oct 25, 4:29pm
Use a distribution block and a fuse for each amp.
Share the REM wire between both
inkapuka, Oct 25, 4:33pm
How would i run the dual coil with the 4 channel would that use all the channels and also can you run two 6x9'swith a 2 channel amp though!
andrea_w, Oct 25, 6:02pm
Mate, I'd highly recommend popping into your local car audio shop and getting some face to face advice.
You'll need just ONE fuse right next to the battery. but the sizes of the cables you'll need before and after the distribution block will need to be looked at - it depends on the amps. You may. or may not be able to run the sub on that 4 channel amp. definitely across 2 channels (but that won't offer any advantage over using the 2 channel amp), but you may not be able to bridge the front channels of the 4 channel amp (to use all 4 channels on the amp), not all amps can.
A pair of 6x9s will happily run on a 2 channel amp. question is, SHOULD you be. I'd be running front speakers on an amp over the rear speakers.
Sounds like the amp will be underpowered for the sub you have. but without RMS rating of the sub, RMS rating of each channel of the amps/RMS rating bridged, the amps Ohm stability per channel, the Ohm rating of the sub etc etc it's hard to give specific advice, and it's hard to give detailed advice like this over the net.
Then RCAs can get tricky too if you don't have the right outputs on the stereo
sparkles_bc, Oct 25, 7:09pm
As above, too many factors to get into specifics, ideally you do want a separate fuse for each amp in case one amp carks it and kills the other from a surge.
The impedance and voice coil configuration of the sub along with the amp ratings are important to check and match as it could overload your amp.
Yes you can run two 6x9s from a 2 channel no problems
n1smo_gtir, Oct 25, 7:34pm
then again most car audio place usually keep that valuable knowledge to themselves as the selling of the install itself is worth alot more in profit than the gear they sell you. if they gave everyone helpful advice they'd loose business.
andrea_w, Oct 25, 8:11pm
Where I worked, if someone came in with the right attitude wanting advice etc anyone who worked there would have been more than happy to help. a sale could be made too from the fuse/fuse holder (the normal inline fuse/fuse holder probably won't be big enough for these 2 amps, the larger type will be required), possibly RCA splitters, large gauge power/earth cable, terminals etc. and after all that, the customer may decide they want a pro to fit it anyway.
It's just good customer service. and that word would get spread around!
dunedin_moto, Oct 25, 9:17pm
dunedin_moto, Oct 25, 9:18pm
inkapuka, Oct 26, 3:07pm
Ive got the sub going but its not very loud compred to old amp mayb im bridging does it mtter if you have the sub on left or right pos neg at tje mo its at rear left and right
inkapuka, Oct 26, 3:08pm
Oh and my other amp is mono so does that mean sub only
