Cannot tighten a screw, will it work if i put a few layers of thread tape around it first!
skiff1,
Oct 28, 7:29am
Nope. Use a bigger screw or fill the hole and re drill and tap it.
dasfi,
Oct 28, 7:36am
Bugger, was trying to avoid that
petermcg,
Oct 28, 7:42am
You can also use a screw with a left hand thread as this will work also, but you cant get left handed thread tape so dont try that.
lookoutas,
Oct 28, 7:47am
"Wrong" - you can get left handed thread tape!
ralphdog1,
Oct 28, 7:49am
You don't need to buy left handed thread tape, that is just a dishonest marketing con. Just turn the right handed stuff over and use the other side.
dasfi,
Oct 28, 8:14am
Sweet as will try tapping it slightly bigger, didnt really want to as its the screws that hold my Nitro rc motor to the chassis, and the motor is alloy, and dont have much room for error
petermcg,
Oct 28, 9:40am
What are you screwing to is the chassis alloy or plastic.
jason18,
Oct 28, 9:53am
If its something like that just chuck a bit of thread tape on it. Its only a RC car
meathead_timaru,
Oct 28, 10:10am
Have you actually removed it to see if it's the screw or the hole that's buggered!
dasfi,
Oct 28, 10:14am
chassis is also alloy, holes in motor are getting a little flogged out
petermcg,
Oct 28, 2:02pm
You may be able to drill the hole a bit deeper in the chassis, tap it out and use a longer bolt.
meathead_timaru,
Oct 28, 2:09pm
If they're not blind holes or can be converted to through holes with access to the back, put a nut on it.
nightboss,
Oct 28, 2:43pm
Thread tape (and thread paste) is designed for tapered threads, commonly used on pipe and for tube fittings, it fills in minor flaults in the thread form that can allow leakage even when correctly tightened. The best solution for standard threads (non-tapered) is loc-tite or similar products, however the amount of damage and usage you have described above will require a more permanant fix much as MH_T says above.
nightboss,
Oct 28, 2:43pm
Thread tape (and thread paste) is designed for tapered threads, commonly used on pipe and for tube fittings where the liquid or gas is at higher than atmospheric pressure, it fills in minor flaults in the thread form that can allow leakage even when correctly tightened. The best solution for standard threads (non-tapered) is loc-tite or similar products, however the amount of damage and usage you have described above will require a more permanant fix much as MH_T says above.
skiff1,
Oct 28, 5:30pm
Try knead it or similar if it is just a toy.
neville48,
Oct 28, 6:15pm
put a fine coat of soap on the screw, mix some 5 minute epoxy ,put it all together with the screw at interferance, leave it overnight and the screw should have a new seat to screw into or just leave it screwed up till next time you have to unscrew it.
ml6989,
Oct 28, 8:28pm
If it is holding a motor in you may need to have it LVV certified for your next WOF
fordcrzy,
Oct 29, 5:41pm
yup i'm pretty sure a nitro conversion needs a cert.
bjmh,
Oct 30, 8:46am
go to mitre10 or such and check out tech screws,some have a coarse thread that you can fit in the original stuffed hole
