How can keep my hubcaps from coming off?
nzrys, Nov 6, 5:46pm
They are aluminium on a solid steel rim. The car is a 1960 Chev.
richynuts, Nov 6, 5:55pm
zip-ties
johnf_456, Nov 6, 5:56pm
Zip ties
mugenb20b, Nov 6, 5:57pm
What if the hub cap has no holes!
johnf_456, Nov 6, 6:04pm
drill ones lol
tuttyclan, Nov 6, 6:05pm
Glue them on with silicone sealant glue.You can buy it in a tube,you just need to get hold of a Silicone gun to squeeze it out.
Just carry a screwdriver in the boot in case you need to get the hubcap off in order to take the wheel off.
I did this with my 1960 Vauxhall Victor chrome wheel rings.
fryan1962, Nov 7, 9:58am
+1 for silicone
lookoutas, Nov 7, 10:01am
It's a 60 Chev John!
lookoutas, Nov 7, 10:08am
If you use any silicone based product, I would only apply 4 or 5 dobs spaced around the rim.
Have seen people go to the trouble of making a bracket that fits on with the wheel, that has a centre stud so john can drill a hole in the centre of the hubcap for the stud to poke through - and screw on a spinner. Which doesn't look out of place on the right car.
johnf_456, Nov 7, 10:28am
So, its just one of the options for a secure solution. If you want to make holes do it that way if you like none glue it as above. No right answer just what one prefers.
Johnf_456
Edit: post 9 is what i was thinking
bigblockf, Feb 6, 5:51am
Achtung ! Warning ! don't use acid cure silicone ! get "neutral cure" the acid cure will start corrosion! (sgrants on bigblockf's pc!)
