92 teranno
luge_boy, Nov 13, 5:50am
my teranno has just sprung a water leak but its coming from a small L shaped house by the firewall. I called a local wreckerand when I explained the part I was after he abruptly stated "we dont deal with little bullshit like that" and hung up.
It may only be a small part and very inexpensive but is this not the purpose of most wreckers, for joe blogs to get random parts from dead vehicles!
r15, Nov 13, 5:55am
if the wrecker is busy, with better things to do, you may be a waste of his time.
probably could have said it more nicely,just move on to the next one.
luge_boy, Nov 13, 5:59am
Yeah I will be finding it elsewhere (i havent been able to find one yet tho)
Was just shocked that he responded that way
intrade, Nov 13, 6:00am
do you ever have antifreeze in your cooling system! and change it every 2 years as it suposed to be !
kazbanz, Nov 13, 6:19am
Op -this small L shaped HOUSE you refer to. Do you mean housing or Hose or do you mean a plastic/steel pipe!
If it is the part I'm thinking of I understand the wreckers reluctance and STRONGLYrecommend you purchase a brand new part from Nissan or possibly a speciallist dismantler who has the part new on the shelf.
Your Little leak is pretty soon gonna be a big expensive problem if left.
The alternative is for now to disconnect said pipe and simply loop out the heater untill you can afford to replace the part.
luge_boy, Nov 13, 6:36am
All coolants were done approx 2 months ago, the rubber hoseis approx 200mm total length but in an L shape only a small diameter. The truck isnt really being used at the moment due to this leakso there isnt really a chance for it to get worse
kazbanz, Nov 13, 7:24am
LB- its a small leak now but what happens when it becomes a big leak! -water sprayed everywhere and a cooked engine would be my thought.
Again if its what I think it is you will see one hose going into the firewall and another coming out.By just looping thoose hoses together the cars driveable just no longer has a heater-till you can buy the part new from nissan or maybee appco
un_known, Nov 13, 9:17am
yeh thats wreckers for ya.some are good and go out of their way to help you with little bits of junk. then theres others where if your not after a front cut or an engine for an insurance repair then they cant be bothered with you.
mugenb20b, Nov 13, 10:23am
I doubt that's going to make any difference at this point in time.
intrade, Nov 13, 2:08pm
yea well myght drive it to the metal recicling instead of fixing it if he never had antifreeze in it as that be only the start of his problems.
