Where to get a 10" low base Air Cleaner?
monaro_girl, Nov 26, 6:09pm
I have a 14"air cleaner and it hits the bonnet.so needing smaller.or other ideas welcome. They are hard to find
berg, Nov 26, 6:47pm
http://www.americanautoparts.co.nz/
These guys should be able to help
treachug, Nov 26, 8:34pm
14" is normally diameter.how high is it! 2" or 3" or 4" etc
Is the aircleaner base a flat type or is it the drop base type! If flat base could you get away with a drop base!
incar., Nov 26, 8:57pm
try STA parts
E1208
Air Cleaner Chrome 10 inch diameter with 2 inch element (3-1/2)
lordv81, Nov 27, 4:28pm
OP are you running a rochester or holley!if you use a drop base on a rochester you have to get the right type as the rochesters have pump linkages at the top near where the base sits.Some holleys also have clearance problems but are generally better.Tell us what engine/carby set up you have!
