Certification
marrriedwomen91, Nov 28, 4:54pm
hi i brought a bmw 92 manual a couple of weeks ago i was told by the seller that they had taken out the original 1.6 engine and replaced it with a 1.8
will i need to get it certified to pass the next wof
andrea_w, Nov 28, 4:57pm
Yes.
Assuming the WoF place picks up on the non standard engine
marrriedwomen91, Nov 28, 4:58pm
ok sweet as thanks
twink19, Nov 28, 5:10pm
try with out cert
intrade, Nov 28, 5:19pm
normally only need cert if its had to be modified on engine mounts or other obvious structurual weldings. Dont know if exess horspower also needscerting in europe its 20% above original engine needs certing
like i fitted a 2.2 liter diesel in to my 2,4 hilux with 60 less horsepowe and same engine mounts no cert required.
NZTools, Nov 28, 5:23pm
If the size of the engine increases or decreases, ie 1.6L to 1.8L , you need a cert.
If the HP increases or decreases by 20% or more, you need a cert.
Will they notice the engine change! probably not.
morrisman1, Nov 28, 5:25pm
because you have increased the engine capacity you need cert regardless. Try without because it will probably slip through easy enough provided the engines look the same and the inspector doesn't check the numbers. Cert is a worthwhile thing for safety in some cases but in cases like these it is a complete waste of time.
