Radar detector
inkapuka, Dec 2, 12:16pm
Im in need of a hardwire kit for a belectronics rx65 pro where do i get them from
meathead_timaru, Dec 2, 12:36pm
Jaycar. Buy the parts, make your own. They're just RJ45 connectors aren't they! It's not rocket surgery.
But if you insist on buying one.
http://tinyurl.com/cjj56hf
ntalke, Dec 2, 1:07pm
When you have done that ,get some 3M Dual Lock to mountout of sight above the Rear vision mirror(depending on vehicle) and is a permanent mounting solution
http://www.ramsolutions.co.nz/lifestyle/shop/3m-dual-lock/dual-lock-sj3552b-2x-4x1-black-type-170400-mid-strength
inkapuka, Dec 2, 2:11pm
Sweet thanks guys
inkapuka, Dec 2, 2:12pm
It has a plug like a phone line in house maybe diff though
meathead_timaru, Dec 2, 2:39pm
Or are they RJ22 or RJ44! RJ45 is a ethernet type isn't it! I can't remember. Anyway, I'm sure they're a standard plug, whatever it is.
Just check the output voltage of the existing adaptor first. You may need a resistor in series to drop it from 12V.
ntalke, Dec 2, 2:56pm
inkapuka, Dec 2, 3:53pm
How is that mounted to the window mine will be simmilar just in a vx commodore also has black dotted sh1t above mirror
nightsky1, Dec 2, 5:39pm
.or don't drive like a dick.
that also works
flack88, Dec 2, 5:46pm
Thought that would happen.
